Hi, had a little difficulty setting up my new pike 140's on my killer bee, thought id share my findings as it might help someone else.
Bike: Norco Sight 7.2c
Model Pikes: 2015 Solo air 140mm
sag%/Psi: sticky 20%/85psi
no. tokens: 2 tokens
Fully kitted weight: 95kg
Paired with the cane creek db inline, its been a little difficult to set up, due to the ccdb being a complex shock....I like to try and consider how it all works as a package.
I found that as I honed the settings in on the ccdb, the characteristics of the pike became much clearer. This may be also due to the initial stickiness of the fork, which is much less after 4 weeks of use.
Reccomended pressure for the pike is 95psi and the fork came with 1 token. Tried 0, 1, 2,&3 tokens at 100psi down to 75 psi.
Settled on 85psi with 2 tokens. Asking around, I found that others all seem to be running less than the reccomended pressure. Hardly need to touch the compression dial.
Settings on the ccdb are all per the cc reccomended tune for the sight, at 17mm sag, with extra 1/4 turn on the low speed compression.
Final results are nothing short of oustanding, particularly small bump sensitivity. I havent hit anything bigger than 8-10ft gap yet though. I have 15mm of unused travel after most trail rides, so a little left in reserve for when the bigger hits arise.
