Settings on 2007 Marzocchi RCX2's
CraigS
I figure both 888's and 66's would have the same type of settings in the RCX2 so, can anyone who has used either of these forks tell me how they set them up. I've nutted out both compressions and rebound but am not so sure on the air preload. The manual says to use anywhere between 0-15psi but I just wanted to see what other people use. I range from 75-80kg if that helps. They feel awesome riding around the street but I don't want to bottom out of the first drop I do if there's no air in them. Also do you use the same amount of air in each leg?
Cheers
