The chains fall off? This is getting kinky, please go on!EVERTHING shifts nicer without the clutch. Did I stutter?
But it’s like unprotected casual sex…not worth the fallout.
Allegedly.
Nothing kinky. R’n’R gold stings like a bitch though, and the clutch is a bit sticky.The chains fall off? This is getting kinky, please go on!
no excuses now... 160mm. You could win a DH national with that sort of travel.Right in the feelings.
*willno excuses now... 160mm. You could win a DH national with that sort of travel.
Maybe, maybe the bike could. But me? Unless the rest of the field is DNS or DNF, no chance.no excuses now... 160mm. You could win a DH national with that sort of travel.
I also hate brake failures.Occasionally I go quite fast, but it’s normally more by chance than intent.
Saw me mentioned here.... Standard HyperGlide (HG) which has been around since about 1990 and used on everything from 6- to 11-sp. has ramping on the outboard faces of the sprockets to help shifting to a bigger one (downshifting). Chain link profile helps hang onto the ramps through the shift to reduce slip. Low-profile "drop teeth" at certain points around each sprocket aid shifting in both directions.12 speed stuff from what I understand has profile plates on the chain and cassette which allow shifting both up and down the cassette under load (Hyperglide + I think it's called). The regular 11 speed only allows this when shifting up. I am sure Ducky will correct me if I am wrong. Anyway I have ridden Shimmy 12 speed and yes it shifts very smoothly, but have had several mates who have had clutch issues, the price of consumables is considerably higher and you obviously have to stump up for a new freehub to run it. For the benefit of a slighly wider range (which you can pretty much solve by using an XD freehub regardless) there's not enough benefit for me to want to upgrade.
Got the full 11spd XT group sitting here. It's chunky stuff.Bump.
Does anyone have any experience with the 10 or 11 speed linkglide?
Humble pieYes seen it a while back... probably April 21.
Haven't seen any of it for sale since though.
It really is taking the E 'optimised' to the extreme, what a pile of wank.
You like it? What you change it from?Got the full 11spd XT group sitting here. It's chunky stuff.
Need to clean the chain, wax it and waiting on a HG freehub.
I got the full group from here. Out of stock now.
Was the cheapest around.
Shimano Deore XT Linkglide 11 speed groupset 11-50t - Commuter Cycles
Shimano's Linkglide is directly aimed at e-bikes. It's built tough and robust to take on all conditions, this makes it a fantastic candidate for a bikepacking rig that's going to see some hellish conditions. shimano claim a linkglide cassette will outlast a regular drivetrain by 300%. Groupset...www.commutercycles.com.au
My eeb came with GX which was stretched and chewed out at 500km. Just put new XT 12 derailleur and shifter on it and then realised when I fitted a new XX1 chain that it was jumping.You like it? What you change it from?
We soon will be:On the flipside, with the added weight and durability, question begs, why not just run gearboxes?!
So this is actually a tempting concept...
Pinion E1.9 and E1.12 e-drive units - Pinkbike
Still why the heck is it 600% gear range?! The speed limiter and and usable traction means you don't need much more than 500% and maybe could get away with 400% for most riders, myself included. Typical german stuff, overly complex, expensive and impossible to get.We soon will be:
Agreed, reckon I've went into the big 52t by accident maybe once or twice, 42t occasionally on steep but gears 3-7 (10,12,14,16,18,21,24,28,32,36,42,52) are shark toothed and even after using a Dremel to smooth them off, the torque of the motor plus my megawatts is enough to make a new XX1 chain ride up and jump on every effort.I run 8 speed on the ebike for commuting and it's bulletproof. It's ironic that with the additional motor, people (manufacturers?) rekon they still need pizza sized cassettes and a million gears. You don't the motor takes up heaps of the load and you don't need perfect cadence matched to the load like you do with leg power.
Yep that's why I'm considering the 10 speed shimano linkglide as I dont need that range. For a gearbox though, I doubt it would be much lighter with only slightly less range.Still why the heck is it 600% gear range?! The speed limiter and and usable traction means you don't need much more than 500% and maybe could get away with 400% for most riders, myself included. Typical german stuff, overly complex, expensive and impossible to get.
Given the ratio steps are the same I'm guessing it's the same gearsets/planetary groups as the C1.12.Still why the heck is it 600% gear range?!
