Hey mate a 250lb spring would be suitable for you but im pretty sure fox dont make a 250lb spring. If you want a 250lb spring you would have to go Ti witch is pretty expensive. Your better off getting 300lb fox springHi, I'm 11 yrs old and weigh 40 kgs. I have a fox van-r rear coil shock. Would a 250lb spring be suitable for me?
thanks!
Depends on the type of suspension. Different suspension applies different amount of leverage. WHat sort of bike is it? At your weight and age, you will pretty much need the lightest spring you can lay your hands on.Hi, I'm 11 yrs old and weigh 40 kgs. I have a fox van-r rear coil shock. Would a 250lb spring be suitable for me?
thanks!
Fox makes a 250lb spring for the DHX5, not sure if this fits the Van-R. Like the man says above, this question should be in Parts N Stuff, don't forget to specify the type of riding you are doing.Hey mate a 250lb spring would be suitable for you but im pretty sure fox dont make a 250lb spring. If you want a 250lb spring you would have to go Ti witch is pretty expensive. Your better off getting 300lb fox spring
