Didn't i just give him the same answer? Why repeat it?BM epic is right as long as you are using tubes and not tubeless,you should be alright ,unless the hole is too big!
he's been re-posting peoples stuff all day.Didn't i just give him the same answer? Why repeat it?
You should just slow down mate,think about things,and only if you can contribute should you post.
It is not a race to see who can have the highest post count!
This bloke is like a plague,he is spreading at a rapid rate all over here!he's been re-posting peoples stuff all day.
Hi, just hoping to clarify this one...I am running larssen tt's,with rip's and tears all along both tyres,i used an inner tube to patch up these holes(from the inside),as long as you are using tubes and not tubeless,you should be sweet,unless the hole is too big!
Try patching it, you should be sweet. Only problem will be if you manage to scrap it up really hard against a rock in the same place. Such a shame on a brand new tyre =(Hi, just hoping to clarify this one...
I've acquired a small tear ~13mm on the side wall of my brand new tyre. The tube was bulging out through the hole. Does this indicate the hole is too big to repair?
cheers!
A piece of vertical blind type material placed inside the tyre can also be very useful. I have done this on a Larsen TT. Cut the blind material so it fits nicely inside the tyre and well over the rip/tear. Then carefully place it in between the tyre and tube, slightly pump the tube just to hold the patch and fit the tyre.Just a quick question to those in the know...
Have a set of maxxis ignitors (non UST) and one of them in a small section (1-2inch) on the side wall has torn away from the Wire bead.
Is it stuffed? it cant be used can it?
