Mobywan
Item: Specialized 2009 Myka FSR Expert Medium
Item Condition: Excellent, hardly used.
Reason for selling: hardly used
Price and price conditions:
Extra Info: A few minor upgrades including ODI Oury Lock on Grips, Sunline 680mm H/Bars, Ethirteen 32 Black Bashguard to replace the outer ring (much better clearance). Outer chainring can be provided though if that's what you'd prefer. Bike has been used for light trail riding by my fiance for about 18 months then has been stored inside the house for the last 12 months. It's in great shape with just a few small marks on it but nothing that detracts from the appearance or peformance. Inspections welcome and would consider postage at your cost also.
Pictures: Yes
Myka FSR Expert
Easily the most versatile XC Trail bikes on the market, these models are known for their smooth riding, trail-tuned suspension and all-day flow. Handling rocky descents and serpentine singletrack with a sweet blend of power, control, efficiency and superior handling.
FRAME Myka FSR M4 Manipulated Alloy tubing w/ new rocker design, Designs for Women geometry and women's specific TT & DT, W/O canti boss, disk only routing, bolt on cable guides, 100mm travel
REAR SHOCK X Fusion 02RC, Specialized Designs for Women tuned, rebound and compression adj. w/ LO, 7.5x1.5", 2 bearing upper shock mount
FORK RockShox Recon 335 SL, 100mm travel, 32mm alloy stanchions, alloy steerer, disc only, Turn Key damper, rebound adj. w/ LO, air spring
HEADSET 1-1/8" Threadless, loose ball bearings w/ seals, black steel cups
STEM Specialized adjustable rise, four bolt 31.8mm clamp, 3D forged, S:75mm, M/L:90mm
HANDLEBARS Sunline 680mm low rise
GRIPS ODI Oury Lock-on
FRONT BRAKE Avid Juicy 4 RSL Hydraulic Disc Brake, alloy backed organic brake pads, tool-less reach adj., cleansweep 160mm rotor
REAR BRAKE Avid Juicy 4 RSL Hydraulic Disc Brake, alloy backed organic brake pads, tool-less reach adj., cleansweep 160mm rotor (was upgraded from a 140mm).
BRAKE LEVERS Avid Juicy 4RSL Hydraulic
FRONT DERAILLEUR Shimano Deore, 34.9mm clamp, top swing, bottom pull
REAR DERAILLEUR Shimano RD-M772 Deore XT Shadow, long cage
SHIFT LEVERS Shimano SL-M531 Deore, trigger
CASSETTE Shimano HG-50, 9-speed, 11-34t
CHAIN KMC X9, 9-speed SRAM Powerlink
CRANKSET Shimano FC-M521, Hollowtech, Octalink spline, replacable rings w/ alloy outer, S/M: 170mm,
CHAINRINGS Shimano 22S x 32S (44 outer ring will be included if required)
BOTTOM BRACKET Shimano BB-ES25, Octalink spline, cartridge bearing
PEDALS: Flats as shown
RIMS DT Swiss 445D, disc, 24mm, double wall, pin joint, eyelets, 32h
FRONT HUB Specialized Hi Lo disc, CNC flange, QR, 32h
REAR HUB Specialized disc, sealed cartridge bearing, high/low flange w/ OS contact side, 32h
SPOKES 1.8mm (15g) stainless, black, alloy nipples
FRONT TIRE Specialized The Captain Sport, 26x2.0", 60 TPI, wire bead
REAR TIRE Specialized The Captain Sport, 26x2.0", 60 TPI, wire bead
INNER TUBES Specialized Ultralight 26x2.0", presta
SADDLE Specialized Windie XC Women's, 143mm width
SEATPOST Specialized 6061 alloy, black, 30.9x350, setback head, 2-bolt micro adjust
SEAT BINDER Alloy collar with QR, 34.9mm clamp ID
Pictures: Yes
Myka FSR Expert
