SOLD! will update subject line when I get home.
2012 Giant Trance X0 (26 inch wheels) in size Large
Melbourne (northern suburbs, pick-up preferred).
Since I bought this bike from Phantom Cycles in Sydney (as an ex-trade-in), I've clocked up 3,100km on it, mainly XC riding. The biggest drop I've done on it is about 40cm - I'm old and scared!
Reason for selling: recently upgraded to 650B 1x11 hardtail - which I now need to reimburse myself for.
Asking $1,000 as is.
NOTE: There is an extra set of Stans/SLX wheels, with good tyres, which I want an extra $200 for - otherwise I'll keep them for my _old_ bike. These are the wheels I used most often, and the tyres are very good.
Extra Info: As per photos, includes original Giant Contact dropper post, which I swapped out when I realised I wasn't using it.
Frame: 2012 Giant Trance X0 (large) with cable routing for dropper post and 5-inch travel.
Shock: Fox RP23 with volume reduced by AstroboyRacer in Collingwood - it was too bouncy for my XC style. Works fine but could probably do with a service. No lock-out function.
Fork: Fox Talas RL Evolution - 15QR axle, 125-140mm travel, compression, rebound, lockout (no remote).
Brakes: Shimano SLX:
Levers - BL-M675-b SLX
Calipers - BR-M675 SLX
Rotors - SM-RT-67-M 180mm Centrelock
Included wheelset:
Wheels: Shimano XT UST tubeless (24-spoke), with QR15 front hub.
Hubs: WH-M788 XT
Tyres: Maxxis Ignitor UST 2.35 (95% tread) and Maxxis CrossMark UST 2.35 (75% tread)
Drivetrain: 3x10 SLX with XT cassette and Ultegra chain.
Levers: SL-M670-b (mounts direct to brake lever)
Rear derailleur: RD-M675 SLX clutch-type
Front derailluer: FD-M670 SLX top-pull, clamp-on
Cockpit: original spec Giant Contact bars & stem. Straight seat post purchased after market.
Stem: Giant Contact 8 degree x 100mm OD2 standard
Bar: Giant Contact 690mm x 19mm rise x 31.8 clamp diameter
Grips: Oury lock-on, white
Post: Giant Connect 30.8 x 400mm
Saddle: Selle Italia with alloy rails and cut-out
Seatpost clamp: Giant alloy bolt-up (no QR)
Additional wheelset (add $200):
Wheels: Stans ZTR Crest rims on Shimano SLX hubs with Centrelock brake rotor mounts.
Tyres: Maxxis Ardent 2.4 (non-UST, but running tubeless - about 70% tread) and Maxxis High Roller II 2.4 (EXO - also running tubeless - 90% tread).
Standard spec is here: http://www.giant-bicycles.com/en-au/bikes/model/trance.x0/9718/50946/#specifications
Please note that the SLX groupset was brand new when I acquired the bike second-hand (which was originally specced with XT kit).
Please contact me via PM. Any questions you may have I'll be happy to answer.
Cheers!
Emerson
Included wheelset:
Hubs: WH-M788 XT
Cheers!
Emerson
