VIC SOLD 2017 Stumpjumper Comp Carbon 29/6 Fattie - Large PRICE DROP $3750
Grant Stubbs
Item: 2017 Stumpjumper Comp Carbon 29/6 Fattie - Large
Location: Melbourne, can also deliver to Sydney and box up for interstate
Item Condition: As new, done 2 weekends riding.
Reason for selling: not using, change of direction
Price and price conditions: $3750 neg
Extra Info: Has done 2 weekends riding. Thought I would be heading to the mountains more and using it but just hasn't panned out. Upgrades inc Thomson Carbon bars, includes XT trail pedals, als set up tubeless, GRID tyres changed out for purgatory front and fastrak rear, can include as new Buthcher and Puragtory GRID that came with bike
Pictures: like this the attachment, actual to follow
Standard specs:
https://www.specialized.com/au/en-au/115307
FRAME:FACT 9m, carbon front chassis, M5 alloy rear end, Trail Geometry, SWAT™ Door integration, PF30 BB, fully enclosed internal cable routing, ManFu link, 12x148mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 135mm of travel
FORK RockShox Yari 29/27.5+, Solo Air, rebound & compression adjust, 15x110mm Maxle Ultimate thru-axle, 150mm travel
REAR SHOCK: RockShox Monarch RT, Rx Trail Tune, AUTOSAG, rebound and 2-position compression adjust, 197x48mm
FRONT HUB: Specialized disc, alloy, sealed cartridge bearings,15x110mm thru-axle, 24h
REAR HUB:Specialized disc, alloy, sealed cartridge bearings, 12x148mm thru-axle, 28h
SPOKES: DT Swiss Industry, stainless, 3x, 2.0"
RIMS: Roval Traverse 29, hookless alloy, 29mm inner width, 24/28h, tubeless ready
FRONT TYRE:Butcher, GRID casing, 29x2.3", 60TPI, Aramid folding bead, 2Bliss Ready
REAR TYRE:Slaughter, GRID casing, 29x2.3", 60TPI, Aramid folding bead, 2Bliss Ready
CRANKSET: RaceFace Aeffect, 6000-series alloy, 24mm spindle, 52mm chainline
SHIFT LEVERS: SRAM GX, 11-speed, trigger
REAR DERAILLEUR: SRAM GX, long cage, 11-speed
CASSETTE: SRAM XG-1150, 11-speed, 10-42t
CHAIN:SRAM PC-1110, 11-speed w/PowerLink
FRONT BRAKE: SRAM Guide R, hydraulic disc, organic pads, Guide S4 4-piston caliper, 200/180mm rotor
REAR BRAKE: SRAM Guide R, hydraulic disc, organic pads, Guide S4 4-piston caliper, 180/160mm rotor
HANDLEBARS: Specialized, 6061 alloy, 6-degree upsweep, 8-degree backsweep, 27mm rise, 750mm width
GRIPS: Specialized Sip Grip, half-waffle, S/M: regular thickness, L/XL: XL thickness
STEM:Specialized Trail, 3D forged alloy, 4-bolt, 6-degree rise
SADDLE: Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm
SEATPOST: Command Post IRcc, 12 position micro-height adjustable, alien head design, bottom mount cable routing, remote SRL lever, 30.9mm, S: 100mm, M/L/XL: 125mm travel
SEAT BINDER: Alloy, 34.9mm
