Either would be fine, I'm not worried by colour. The purple ones look cool but is bb a drama to get.Black or purple?
I is also confuse.What do youbwant, 73mm or 83mm? Edit the title if 73mm is what you want.
I had been wondering why a normal shimano bb wouldn't work with similar 83 cranks.I think GXP is a SRAM fucking stupid standard 22/24mm where as RF will cross pollinate with Shimano at 24/24
the width is directly related to the axle length not so much the BB bearings, as they all fit the same thread, its just the plastic weather sleeve that sits in between the two bearing cups that keep out the muck that are different widths, if you can live without the plastic sleeve, any 24mm BB shell should work with the Atlas cranks
No, definitely 83mm. I think the confusion is peeps think it's for the v10. It's for the gt.What do youbwant, 73mm or 83mm? Edit the title if 73mm is what you want.
Must of missed it man, thought you were always on the pulseWhoooooah on there big boy...V10?
Damn! How could you want the gt when you've now got this beast?Must of missed it man, thought you were always on the pulseView attachment 363511
That looks like the SC. V10 V2 (not a nomad) which ran a 73mm bottom bracket. He wants cranks for that newer gt frame which runs an 83mm bottom bracket.And it’s got cranks....so why do you need some?
not every SC is a Nomad!....V10 perhaps>?That looks like the V2 nomad which ran a 73mm bottom bracket. He wants cranks for that newer gt frame which runs an 83mm bottom bracket.
The answer will never come...And it’s got cranks....so why do you need some?
I put the right link! My phone must have been monitoring my incognito private time searches again.not every SC is a Nomad!....V10 perhaps>?
YepThat looks like the V2 nomad which ran a 73mm bottom bracket. He wants cranks for that newer gt frame which runs an 83mm bottom bracket.
Got it mostly for the parts, all in pretty good nick so will go on the go.First time I have heard of someone buying a bike for a BB. Must have been cheap.
