Item: Ibis Mojo SL, Large, with latest links and bearings, 140mm travel
Item Condition: Good Condition, well maintained: light cratches / rub marks from normal use, no known structural damage to frame or components. All in good working order.
Reason for selling: New bike
Price and price conditions: $1700, will consider a drop off if nearby 1.5 hrs
Extra Info:
http://www.ibiscycles.com/bikes/past_models/mojo_sl/
Rockshox Revelation RCT3, 140mm travel 15mm axle (New in 14)
Rockshox, Monarch Plus Rear shock (New in 14)
XTR cranks with Oval ring 34 teeth (some scratching from my Gripsport rack)
Shimano Zee Rear Der, set up 1 x 10 (Cassette 11-36)
BB and Chain XT (Replaced in Nov 15, little K's)
KS Dropper post
Bontrager Alloy bar with grips (New not used)
Easton 85mm Haven stem
Shimano Deore brakes, (new not used). 160mm XT Center Lock Discs used.
DT Swiss 240 hubs on Stans Olympic rims 26, set up tubeless (Maxxis High Roller front, Ardent Race back)
Front is 15mm x 100, Rear is 10mm x 135 on the hub end caps.
Weight as shown is 11.4 kg (No pedals)
Will come with original DT Swiss shock, has damage on stanchion but I use it for XC days and runs ok (Done this with fixed seat post to drop weight)
Pictures:
Extra Info:
KS Dropper post
Pictures:
