Item: Light & Motion TAZ 1200 ($379 RRP)
Item Condition: Brand new & unused
Reason for selling: Surplus to requirements
Price and price conditions: $170
Pictures: Attached
Extra Info:
This is a brand new Light & Motion TAZ 1200 light that has never been used. I don't need it as I use the Seca light instead. Given that it's brand new, it is in perfect condition with no damage and no wear and tear present - it has literally only been taken out of the box to take photos.
Retailing for $379, the TAZ 1200 is a powerful 1200-Lumen light that features a compact design that integrates the LED and the Lithium-Ion battery into a single alloy housing. It's waterproof and is also designed to be durable for mountain bike use.
"The all-in-one bar mounted light that is bright as a car headlamp in a compact size. Perfect for any type of cycling - from serious road or trail rides, to daily commutes" - Light & Motion
Features:
• RRP: $379
• 1200 Lumen output certified to the FL-1 Standard
• Engineered with a 3 LED array using the highest level CREE LEDs.
• Custom engineered reflector/optics diffuses the bottom LED to cover an ultra-wide spread down in front and focuses the top two LEDs to penetrate the darkness with a far-reaching beam, without wasting any light.
• Beam pattern was engineered to maximize visibility at high velocity with ample beam distance lead-time and the widest beam angle for the sharpest turns.
• Side lighting to maximize visibility on roadways with a dedicated button to toggle the side lights on/off.
• IP67 Rating - Tested to be fully waterproof in 1 meter of water for 30 minutes
•Includes: Handlebar mount, 4 foam strips, thin mount pad, micro USB charging cable
Pictures: Attached
Extra Info:
Features:
• RRP: $379
