red_dog
Item: Complete 2012 Specialized Demo 8 II, Large Frame Black Red & White in colour
Item Condition: Excellent, well maintained, serviced regularly.
Reason for selling: Only reason for the sale is the arrival of a 2013 carbon version of same.
Price and price conditions: $3,500.00, willing to post nationally at buyers expense. Possibly suggest airport to airport through AAE for quick cheap turnaround.
Extra Info: For more information please contact Kaine Cannan on 0419 597 896 or kaine_cannan@hotmail.com
Frameset
Front Travel 200 millimeters
Frame Material Aluminum Frame M5 manipulated alloy, compact race design, 1-1/2" forged HT, magnesium link, ISCG 05 mount, cartridge bearing rear shock mount, rear derailleur protector, 200mm travel
Frame Size LG (19"-21")
Fork RockShox Boxxer World Cup, Mission Control damper, alloy steerer, low/high speed compression and rebound adj. w/ bottom out control, 20mm Maxle DH thru-axle, 200mm travel
Rear Shock Cane Creek Double Barrel, coil over w/piggy back, high/low speed compression and high/low speed rebound, 9.5x3", L:450
Drivetrain
Crankset SRAM X0 DH, carbon arms, single ring, PF30 spindle, 165mm, w/Gamut P-30 chainguide
Cassette SRAM PG-1050, 10-speed, 11-26t
Rear Derailleur SRAM X0 DH, 10-speed, short cage
Shifters SRAM X9, 10-speed, trigger, w/MatchMaker clamp
Components
Brakes Custom Avid Code X0 World Cup
Front Brake Custom Avid Code X0 World Cup, hydraulic disc, tool-less reach, Code caliper, semi-metallic pad, stainless hardware, 200mm rotor
Rear Brake Custom Avid Code X0 World Cup, hydraulic disc, tool-less reach, Code caliper, semi-metallic pad, stainless hardware, 180mm rotor
Brake Levers Custom Avid X0, carbon blade, tool-less reach adj., w/MatchMaker clamp
Handlebars Renthal Fat Bar, 780mm wide, 7º backsweep, 31.8mm
Stem Specialized Direct-Mount stem, 40mm length, 31.8mm, 4-bolt, forged
Headset 1-1/2" integrated for 1-1/8" steerer, cartridge bearings
Seat Post Thomson straight w/ 12º clamp, 367mm
Saddle Specialized DH, 8mm hollow Cr-Mo rails
Grips ODI Ruffian
Wheels
Rims Front: Roval DH 32h, Rear: DT EX500 32h
Front Hub Specialized Hi Lo disc, laser-etched logo, sealed cartridge bearing, 20mm thru-axle, 32h
Rear Hub Specialized Hi Lo disc, 150mm, hollow 12mm Cr-Mo axle w/ RD guard, 32h
Spokes DT Swiss Competition 2.0/1.8/2.0mm stainless
Front Tire Specialized Butcher DH, DH casing, wire bead, soft dual-compound, 26x2.3"
Rear Tire Specialized Butcher DH, DH casing, wire bead, soft dual compound, 26x2.3"
Pictures: See below
Frameset
Drivetrain
Components
Grips ODI Ruffian
Wheels
Pictures: See below
