Item: 2014 Norco Sight 7.2
Item Condition:Excellent
Reason for selling:Don't have time to ride anymore
Price and price conditions:$2200ono
Extra Info:Has only been ridden a couple of times. Small frame size.
Pictures: Yes
Spec:
FRAMESET
FRAME Sight 27.5 140 mm travel
FORK Manitou Minute Exp TS 140 mm TS Air QR 15
REAR SHOCK Rockshox Monarch R high volume air shock
WHEELS
RIMS Alex TD 26 27.5 mm double wall 26 mm wide
TIRES Kenda Honey Badger 27.5 x 2.35 DTC Kevlar
TUBES N/A
FRONT HUB Joytec alloy MTB w/disc 15 mm axle
REAR HUB Joytec 142 x 12 12 mm through hole disc
SPOKES/NIPPLES Stainless steel black 2.0 spokes
DRIVETRAIN
SHIFTER FRONT Shimano Deore 3 speed shifter
SHIFTER REAR Shimano Deore 10 speed shifter
FRONT DERAILLEUR Shimano Deore seattube direct mount
REAR DERAILLEUR Shimano SLX Shadow Plus Direct mount type
CASSETTE Shimano HG-62 10 speed cassette
CRANKSET Shimano Deore FC-M615-L 38 / 24T
BOTTOM BRACKET Comes with crank
PEDALS Norco alloy flat pedal Steel insert pins
CHAIN Sram PC 1031 10 speed chain
COMPONENTS
SEAT POST Norco 6061 alloy double bolt head 30.9
SEAT POST CLAMP Norco design alloy nutted clamp w cable guide
SADDLE Norco design trail / XC saddle
SHIFTER CASING Jagwire LEX housing
HEADSET FSA #57 E ( semi integrated ) 1.5" to 1-1/8"""
HEADSET SPACER FSA plastic spacer 1 x 10 mm
TOP CAP Black alloy with no logo
STEM Norco short reach 3D forged
HANDLEBAR Norco 1" rise bar 740 mm width 6061 alloy"
GRIPS Norco design lock on grip
FRONT BRAKE Avid DB1 hydraulic disc brake 180 mm rotor
REAR BRAKE Avid DB1 hydraulic disc brake 160 mm rotor
CHAIN TENSIONER N/A
BRAKE LEVERS Avid G2 180 mm front 6 bolt rotor
Pictures: Yes
Spec:
FRAMESET
WHEELS
TUBES N/A
DRIVETRAIN
COMPONENTS
CHAIN TENSIONER N/A
