Grant Stubbs
SOLD
Item: S Works Epic 29er 2013 XL.
Item Condition: Almost perfect, one rub mark on crank (see pic) otherwise as new
Reason for selling: Upgraditis
Price and price conditions: 3500 + post. Pick up Melbourne. Can probably deliver to Sydney or Newcastle
Extra Info: See below
Pictures: Yes attached
$3500 neg.
I have owned this bike since new and it is in perfect condition. Has done 1597km according to Strava. I can ship for interstate buyer and bring to Sydney / Newcastle as I travel regularly for work
Recent maintenance includes:
•Fork and Shock 50hr service by specialised
•Service new chain, brake pads, bleed, tidy cables, replace lower shock pivot bearing at Total Rush
•Tubeless redone
I am 188cm and fits me well. Would suit down to 184 or so I guess. Specialized XL doesn’t seem as large as other brands, I used to ride a Large Anthem for example. This bike is a fantastic XC rig and weights about 10.5kg, which is pretty light for a large dually. This model was the bike Mountain Bike Action magazine describes as the "best bike we've ever ridden”
Full Specs from Specialized site and updated where I have changed.
FRAME:
FACT 11m carbon front triangle, 29" geometry, FACT IS construction, gussetless TT (S/M), FACT carbon seatstays w/carbon non-drive DO and chainstays, tapered HT, carbon PF30 BB, 142mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 100mm
SWAT: Chain tool in headset, s-works mini tool in cage
REAR SHOCK: FOX/Specialized remote Mini-Brain w/ AUTOSAG, Kashima coating, inertia valve, Brain Fade adjust, 187x47mm
FORK: Custom RockShox SID World Cup 29 Brain, inertia valve damper, Solo air spring, tapered carbon crown/steerer, top-mount Brain Fade and rebound adj., QR, 100mm travel
STEM: Syntace F109, 6-degree rise, 31.8mm clamp, L/XL: 105mm
HANDLEBARS: S-Works XC Carbon flat bar, uni-directional carbon, 680mm wide, 8-degree backsweep, 31.8mm
BRAKE: Magura MT8, hydraulic discs, carbon master cylinder/lever blade, hollow lever pivot, reach adj.
REAR DERAILLEUR: SRAM XX1, 11-speed
SHIFT LEVERS: SRAM XX1, trigger
CASSETTE: SRAM XX1, 11-speed, 10-42
CHAIN: SRAM XX1, 11-speed, hollow plates/pins, nickel finish
CRANKSET: S-Works OS carbon, custom spider for SRAM XX1, 11-speed XC single ring, 34T,
PEDALS: Shimano XT
RIMS: Roval Control SL 29, carbon disc, 28mm wide, 32h
FRONT HUB: Roval Control SL 29, carbon/alloy, OS 28 end caps, QR 32h
REAR HUB: Roval Control SL 29 142+, DT Swiss Star Ratchet, 12mm thru-axle, 32h
SPOKES: DT Swiss Revolution 2.0/1.5/2.0mm stainless, DT Aerolite, bladed, painted
FRONT TIRE: S Works The Captain, Tubeless
REAR TIRE: S-Works Fast Trak, Tubeless
SADDLE: Specialised Power Pro Carbon 143mm, I will also include the standard Body Geometry Phenom Expert,
SEATPOST: Thomson Elite
$3500 neg.
•Tubeless redone
FRAME:
PEDALS: Shimano XT
