Item: Scott Genius 720, Carbon frame, 650b wheels medium, 2013 model
Item Condition: Generally excellent condition - frame skin applied from new, a few wear and scuff marks from normal riding, plus a bit of a scrape on the fork lowers (see pictures) - stanchions are perfect though.
Reason for selling: New bike
Price and price conditions: $1800 or near offer
Extra Info:
- Have owned the bike from new and it has always been well maintained.
- The fork has been upgraded by fox as part of their 2013 recall and has the 'low friction' seals installed.
- The bike has the 'TwinLoc' system which allows you to change both shock and fork between Descend, Trail and Climb settings on the fly using a single, handlebar mounted remote.
- Also has shock mount 'flip chip' which changes the BB height (346mm / 352mm) and head tube angle (67.7 / 68.2)
- All pretty standard apart from being converted to 2 * 10 from new (was 3 * 10) and I've added a dropper post.
Specs: Have highlighted changes from stock in bold
Frame: SCOTT Genius 650b Carbon / Alloy swingarm / Tapered Headtube, IDS SL dropouts for 135 × 5mm, BB height adj. / 150mm rear travel
Rear Shock: SCOTT DT Nude2 / 3 modes Lockout-TC-D, Ball joints / 200 × 57mm / reb. Adj
Fork: FOX 34 Talas 650b Evolution CTD Air, CTD remote damper with 3 modes, 15mm QR axle / tapered steerer, reb. Adj. / 150 – 120 mm travel
Front Derailleur: Shimano SLX M670-E Shimano XT M785 2*10
Rear Derailleur: Shimano XT M786 SGS, Shadow Plus Type
Shifters: Shimano SLX M670, Rapidfire Plus / 2 way release, Ispec clamp
Chainset: Shimano XT M780, hollowtech 2 Shimano XT M785 2*10
Bottom Bracket: Shimano BB71-41A
Cassette: Shimano XT M771, 11-36 Tooth, 10 Speed
Chain: Shimano HG74
Pedals: DMR V12 flats
Front Brake: Shimano SLX M676 Disc, 180mm SM-RT66 IT Rotor
Rear Brake: Shimano SLX M676 Disc, 160mm SM-RT66 IT Rotor
Brake Levers: Shimano SLX M676 Disc
Handlebars: Syncros FL1.5 Tbar, Alloy 7050 D.B. / T shape Flat / 9 degrees / 700mm
Stem: Syncros TR1.5, 2014 / 4D forged / oversize 31.8mm, 1-1/8" / 6 degrees angle
Headset: Ritchey Comp Plus Tapered 1.5" – 1 1/8", semi integr. OD 50/61mm / ID 44/55mm
Grips: Syncros Pro lockon grips
Rims: Syncros / DT Swiss TR 2.5 27.5’’/650b, 28 H
Front Hub: Syncros TR 2.5 650b CL / 15mm made by DT Swiss
Rear Hub: Syncros TR 2.5 650b CL / RWS made by DT Swiss
Spokes: DT Swiss Super Comp black
Front Tyre: Schwalbe Nobby Nic EVO Schwalbe Hans Dampf 27.5 * 2.35
Rear Tyre: Schwalbe Nobby Nic EVO 27.5 * 2.25
Saddle: Syncros TR2.0 / CROM rails
Seatpost: Syncros FL1.5 / 31.6mm Crank Bros Joplin 4 dropper post with handlebar mounted remote
Pictures:
Extra Info:
Chain: Shimano HG74
Pictures:
