Solid Rotors to replace G2's
IceTech rotors (RT81/86/98) are a bitch to straighten 'cos of the alloy rotor ring (which is steel-coated for wear resistance on the faces). It doesn't have the springiness of steel, so they just end up getting kinked & stuffed. I've buggered one up after inflicting a not-that-severe bend in a stack.
No you can't, it's the other way around - it enables you to mount 6-bolt rotors to centrelock hubs.
The hub design of 6-bolt means that there is no way possible to adapt for centrelock rotors.
He's right mate. a 6 bolt hub makes it 6 bolt or nothing. CL is a bit more variable.
I run formula the ones with ice tech rotors and I love them. I've run formula, avid, a2z etc but for me the ice tech rotors are the best for performance and they don't bend like the others.
solid meaning that they are strong, not one solid piece. sorry i wasnt very clear, but i tried to clear it up in the description.
