What I mean by drill bit is to use a drill bit that is slightly larger than the id of the bushing. Screw bit into bushing then use a set of pliers to pull it out.Don't know about Spank 0edals in particular but I use an appropriately sized drill bit to get bushings out of my Time pedals.
Thanks for the clarification.What I mean by drill bit is to use a drill bit that is slightly larger than the id of the bushing. Screw bit into bushing then use a set of pliers to pull it out.
Yep done this with the Spank Spike pedals but can't get through from the other side on the Spoon pedals unless I remove the bearingThe bushes aren't very tight in them, you can push them out with the spindle by hand.
