seanb888
Trying to learn more about how the brain is suposed to operate. Do you mean there should be no sag at all, ie hardtail, or should there be 20% sag still. My 09 epic has the bulge at the top of the brain and I run with 20-25% sag depending on the air pressure. If there is no sag at all then the rear shock would not extend to keep traction over areas where the ground went away. I thought this was correct but now am begining to worry. My shock constantly leaks oil though. Have to look into getting that fixed.Yeah the second is what has happened to mine, with the shock set all the way firm it should be solid and only move when you hit a bump. The first one that died had a heap of sag before it went solid but still worked OK, the second shock as soon as it was fitted I could notice a massive difference and it felt great until I was riding along thinking "is my seat pole slipping" as the bike was feeling a little uncomfortable and then while on a ride we stopped and as I got off the seat I felt the suspension pop back up and the realized as I sit on the bike the suspension is just slowly sagging down until basically the air pressure stops it. Lock out or the "brain" action doesnt work at all anymore.
JED21- did you ever get a response from Specialized.
Cheers Sean
