link1896
Mr Greenfield
Specialized rear shock "Brain" rebuild with pictures & now forks too
Revised orings. Have swapped from polyurethane O-Ring on the bearing to damping rod position to a n70 quad ring. This should delay air pushing into oil chamber when IFP pressure drops below air can pressure, plus there is no need for an O-Ring of this rigidity in this position. I would suggest this was selected by our friends to minimise service life.
Position | Material | ID | CS | PN |
brain adjust knob | buna 70A | 5 | 1.5 | |
top outer of reservior can to machined head | buna 70A | 22 | 2 | |
IFP | buna 70A | 17.07 | 3.53 | BS-209 |
nitrogen stopper | buna 70A | 19 | 2.65 | BS116 |
brain piston OD | buna 70A | 21 | 1.5 | |
hose end x 2 (polyurethane) | polyurethane | 4.5 | 1.8 | BS-008PU |
metering rod to inside of damper shaft | buna 70A | 3 | 1.5 | |
damping rod to inside of end cap | buna 70A | 11 | 1.5 | |
damping body to bearing | buna 70A | 20 | 1.8 | BS-019 |
bearing to damping rod Quad ring | buna 70a | 12.37 | 2.62 | QR-112 |
IFP bleed port | buna 70A | 3 | 1.5 | |
autosag assembly | buna 70A | 34 | 1.8 | BS-027 or BS-028 |
airsleeve to bearing housing Quad ring | buna 70A | 24.99 | 3.53 | QR-214N70 |
backup rings | Teflon | BU-214T | ||
airsleeve to end cap | buna 70A | 33 | 1.5 | |
airsleeve quad ring to damper body | buna 70A | 20.22 | 3.53 | AS568A-211 |
airsleeve quad ring to damper body backup ring | Teflon | BU-211T | ||
airsleeve wiper seal | Urethane | 0.812 | AN 0.812" urethane |
