The embargo stamp was 24/3 I believe so we are getting close. 12sp, 50T-10T - me likey.
the point is a wide gear range with the security of a single ring up front. just because it doesn't suit you, doesn't mean it's not useful for others... (and by the sounds of it, you need to ride somewhere with more hills!)Correct me if I`m wrong , but whats the point ? What front ring will you run with this , 40 ? Won`t you just spin out . Yes I`m considering 11 speed on the AM bike when my current setup is worn ( 2 x 10 at the moment ) but even then I`m thinking of just going 1 x 10 . Its rare I use my granny bail out on the front and if i do I have to shift the rear down or up ? ( harder gear on rear ) to maintain a decent cadence so I don`t feel I`m spinning and going nowhere . All these standards , are they useful or just a gimmick that we buy into ?
28t ring up front with 10-42 on my 29" gives me a top speed of ~57-60km/h according to strava. this was winding it out down a firetrail though, which i might do once in a blue moon. plenty of speed for my usual riding with my pissy little chain ring.
Interesting . I do have plenty of hills . I ran a 28 11-36 for about a year on one of my XC bikes before going back to 2x and my main XC is a 3 x 10 . I keep my AM in the 36 front 98% of the time with an 11-36 and thats on gradients of 20% or more . Just not sure where the benefit is here , god knows I`ve spent the coin on the latest fad without giving it a proper evaluation . My point is where do you use the 42 or even the 50 ( if thats what it is ) not top speed . Anyone can ride at those speeds regardless of what you run .the point is a wide gear range with the security of a single ring up front. just because it doesn't suit you, doesn't mean it's not useful for others... (and by the sounds of it, you need to ride somewhere with more hills!)
hell, there are plenty of devout 2x and 3x fans as 1x10/11/237 doesn't offer them a big enough range.
On the other side of it, the trade-off of getting a wide range on a single ring is that it blows filthy great holes in the mid-range, which might be OK for some people, but others prefer a slicker progression through the gears. As an unashamed devotee of The Triple, what I'd really like to see is a tighter 11-sp. cassette option, 11-38 or even 36 for a really meaty mid-range, because seriously, 22/40 (the current lowest gear on Shimano's 3x11) is just plain ridiculous. 22/36 or 24/38 would be plenty low enough, lower than what's available on 3x10. And then there's the big ring for when things open out.the point is a wide gear range with the security of a single ring up front. just because it doesn't suit you, doesn't mean it's not useful for others... (and by the sounds of it, you need to ride somewhere with more hills!)Correct me if I`m wrong , but whats the point ? What front ring will you run with this , 40 ? Won`t you just spin out . Yes I`m considering 11 speed on the AM bike when my current setup is worn ( 2 x 10 at the moment ) but even then I`m thinking of just going 1 x 10 . Its rare I use my granny bail out on the front and if i do I have to shift the rear down or up ? ( harder gear on rear ) to maintain a decent cadence so I don`t feel I`m spinning and going nowhere . All these standards , are they useful or just a gimmick that we buy into ?
I use my 42 all the time! 10-15 minute sustained climbs warrant it for me.Interesting . I do have plenty of hills . I ran a 28 11-36 for about a year on one of my XC bikes before going back to 2x and my main XC is a 3 x 10 . I keep my AM in the 36 front 98% of the time with an 11-36 and thats on gradients of 20% or more . Just not sure where the benefit is here , god knows I`ve spent the coin on the latest fad without giving it a proper evaluation . My point is where do you use the 42 or even the 50 ( if thats what it is ) not top speed . Anyone can ride at those speeds regardless of what you run .
A big part of it is their chainrings that are cut out of cooked lasagne sheets. The best derailleur has no hope of working on rings that bend out of the way.SRAM have never worked out how to make a front derailleur work. It departed from them before they even started.
