if you're after a fair dink ss ie: not a cassette with 1 cog on it. get as big as you can (the biggest i could find is an 18T) then adjust the gearing with the chainrings, that way you only need a chain tool & some allenkeys & you don't have to frig around with a sprocket remover, much simpler, and that's half the beauty of SS. at the end of the day, you'll probably only be in the right gear half of the time with a ss anyway do don't worry about it too much, just pedal slower or faster. As a side issue, I have found that i'm better off in a lower gear than what i started out DJ'ing in.
