Musgrove
The boys from world trail have finished all the work on the track getting it ready for the World Champs in September. So its all good to go.
The changes have been as follows.
The first straight had the slight kink to the right removed and the last two jumps changed with a rock “suck pit” installed in the last jump.
The first corner has been blown out to be a big burm with the entry and exits extended and a middle smaller burm added.
The second straight is all new with a step down to a Mogul field and a big mogul field.
Second corner was moved further back. It is a big fast burm with a massive Mogul on the inside.
Third straight is longer as the corner before and at the end of it have been moved. The big jump in the straight if bigger leading to a new step up over a log.
The forth corner is now a flat long radius corner with radial log/rock steps. Forth straight is as it was.
Fifth Corner has a new inside rock feature with rock steps on the exit. The middle and out side lines are as they were.
Sixth straight has a new log jump installed.
The Bear trap is as it was
The last corner has been changed to an open burm mane the last jump in the bear trap has been made longer and the landing improved so most riders should not over jump this now
The rest of the track to the finish is basically as it was.
Jeff
Jeff
