what do you mean, tap it like straight down with a hammer? but if it's already lodged into the frame theres nowhere farther down for it to go.By the sounds of it the post is sized in by corrosion of some description, might be worth lightly tapping the seat tube with a hammer, this way it will hopefully break the bond that has formed between the metals. Be careful not to clock it too hard otherwise you will bend the tube and lock it in! this may also allow the WD-40 to soak through!
Trust me... TWISTING is the worst thing you can do, despite the fact that it seems the obvious thing to do. In most cases it will simply make the situation worse because of the very real chance of spooling between the post and tube. It needs to be removed STRAIGHT out and it's probably going to mean you'll need a new post.Clamp the seat post in a vice and turn the frame. This gives greater leverage than trying to grab the seatpost and turn it. You may destroy the seat post with the vice but depends how brutal you are.
No no, tap 'around' the tube, to try and dislodge the bond between the two metals, as in the sides of the seat tube (not seat post)what do you mean, tap it like straight down with a hammer? but if it's already lodged into the frame theres nowhere farther down for it to go.
Use hot water (not boiling, but hot) to heat the seat tube (NOT the post).What material is the seatpost, and the frame? If it's aluminium, it's going to be tricky.
If you are going to tap on the frame, place a piece of wood on the frame, and tap on the wood so you don't damage the frame. It's probably better to tap the seatpost than the seat tube.
If I were you, I'd sacrifice the seatpost:
1. Get a bolt, drill a hole into the seatpost, stick the bolt in.
2. Invert the frame and spray WD40 into the seat tube and let it seep down to the seatpost.
3. With the frame inverted and secure, start tapping on the bolt.
You could also try heating the seat tube - assuming that you are not concerned about the paint / finish as you are restoring the frame - and keep tapping the bolt.
That would hopefully have the seat tube expand more than the seatpost and help free it.
Oh...and if you are using heat, don't forget that WD40 is flammable. I know "mechanics" who in their frustration have forgotten that.
Hmm interesting. So at this point I should not state I used to be a shop mechacnic and this was one of our fall back practices. Our other last resort for alloy posts was to cut it off and use a hacksaw blade to cut throught the internal of the seat post in two places and effectively compress the post to get it out. I should add both of these are last restort practices but ones I have used sucessfully on more than one occasion. (The cut throught requires patients and a steady hand)Trust me... TWISTING is the worst thing you can do, despite the fact that it seems the obvious thing to do. In most cases it will simply make the situation worse because of the very real chance of spooling between the post and tube. It needs to be removed STRAIGHT out and it's probably going to mean you'll need a new post.
And maybe I should not state my experience either, eh?Hmm interesting. So at this point I should not state I used to be a shop mechacnic and this was one of our fall back practices. Our other last resort for alloy posts was to cut it off and use a hacksaw blade to cut throught the internal of the seat post in two places and effectively compress the post to get it out. I should add both of these are last restort practices but ones I have used sucessfully on more than one occasion. (The cut throught requires patients and a steady hand)
Anyhow good luck with the project. Post some pics so we can enjoy.
i really don't care if the seatpost gets messed up as im getting a new one anywayAnd maybe I should not state my experience either, eh?
Oppy, you can state what you like and I never said twisting wouldn't work... just that it's the worst thing to do because if it doesn't work but does spool up then the situation ends up much worse than it would have been with a straight, axial removal.
i took the pedals out today and the post is sticking out into the place where the cranks and pedals are so could i use a hammer and hit the bottom of the seatpost a o you guys think that would work?
Not sure I would do that - more likely to ovalise the seatpost, which might make it harder to remove.Pure speculation here, perhaps using a vice to pinch the seatpost would help... if the bond were on the top part of the seat-tube this would break it... if not it would allow the WD-40 to penetrate deeper (perhaps allowing you to apply it directly onto the bond
