Fcuk you al, subies are for real men...Www.ihavenoideahowtodrive.com or
www.iliketodrive10kphbelowthespeedlimit.com.au or its sister forum. Www.illgiveuptherightlanewhenidie.com.au, or the most active
www.exvolvodriversnowstylingsubbies.cn.com
subby drivers, no need to get offended ... Unless you are one of those^^^^ound:
Thin ice there...Www.ihavenoideahowtodrive.com or
I had the rear left wheel bearing done on my forester last week. your looking at between 350-400 parts and labour for a shop to do it :-(. I did some research and apparently its a bit of a crap job to do yourself unless your confident! Good luck!I had a buyer test driving my forrester today. Was totally happy with it, last 20meters before home a wheel-bearing shit itself. Talk about bad luck. How hard are they to change? I'm a bit time poor right now so my just get a mechanic to do it and take it on the chin. Buyer is still keen and there's a couple others I had to tell about wheel bearing, such bad luck/timing. Strange cause it'd not been driven for a couple of months, seemed to have needed a wheel alignment, so I said to the guy when he arrived, we better drive it to servo to pump tyres up, as it's pulling, he said he didn't notice it.
Are there any sure fire ways to tell it's a wheel bearing without jacking it up?
Full lock made no difference to noise, so guessing/hoping it's not a CV.
Sorry for the derail scblack.
Awww shiat.I had the rear left wheel bearing done on my forester last week. your looking at between 350-400 parts and labour for a shop to do it :-(. I did some research and apparently its a bit of a crap job to do yourself unless your confident! Good luck!
I think GTs now get the P-plate approval nod so you should get appeal from a slightly wider audience.Awww shiat.
Just had valves, timing belt, tensioner, radiator, all fluids replaced. Just trying to sell it, can't believe I'll only get $4500ish for it, such a rad little car(GT).
Blast from the past! Went under a while back.Is gtrydaz still up?
fixed that one for you cuzFcuk you al, subies are for real boyz...
Mines going in for one next week, quoted $380. Just lent it to my brother for a work trip and got it back with a rooted cv, busted sway bar mount and the rear wheel bearing and four new tires ($700+) 3000k closer to needing to be fixed (got $200 from the company for lending the car, they saved a few hundred not having to rent a car and got it back with fuck all petrol and all those new problems, end rant.).I had the rear left wheel bearing done on my forester last week. your looking at between 350-400 parts and labour for a shop to do it :-(. I did some research and apparently its a bit of a crap job to do yourself unless your confident! Good luck!
Its a 2.5 I am going to get the CV joints and head gaskets checked out. Plus general check-over. Maybe now wheel bearings too..... If it's an 04 the 2.5 should be good, the NA 2.0 can be a bit gutless with passengers and bikes.
Ahhh sweet. thought that was the main market killer. Is a fast little car for a newb, but handling makes up for it I guess as far as safety goes.I think GTs now get the P-plate approval nod so you should get appeal from a slightly wider audience.
recently traded a liberty, took it to my regular mechanic to get all the stamps in the service book. On the way home (ie last time I would drive it before the trade in) check engine light comes on. Never seen it in 8 years so brilliant timing. Went back to mechanic who couldn't find anything and reset the warnings.I had a buyer test driving my forrester today. Was totally happy with it, last 20meters before home a wheel-bearing shit itself. .
