What Moorey said. .. flip it over and under, keeps the lever safe and out of the way.Run it upside down. Keeps it out of harms way better. Mine came righty, wanted lefty, this is even better.
Wouldn't running a matchmaker only make one less clamp if he's running the reverb button flipped?Btw... I know why I run avid, sram and rock shox... cleans the bars up big time. .. That shimano setup is busy to say the least
Heard of iSpec?What Moorey said. .. flip it over and under, keeps the lever safe and out of the way.
I can't fit it up against the grip as the right angle turn that the reverb lever makes contacts with the brake lever or the shifter pod. Maybe xtr shifters are skinnier?Yep, that's pretty much the issue that I have but I can get it a bit closer so it's manageable. Def prefer to run it up against the grips tho.
starting doing stuff with your left hand and stop being such a nancyI can't fit it up against the grip as the right angle turn that the reverb lever makes contacts with the brake lever or the shifter pod. Maybe xtr shifters are skinnier?
