safreek
ITEM : charge duster, complete bike, presume from 2009 as the forks are from 09
LOCATION : Lismore nsw, can travel reasonable distance for trade. (bris to coffs ) not keen to post unless you make it worth my while
PRICE : swap for single speed wheelset 135mm, 20mm, disc capable. if you had a spare dj fork to chuck in I wouldn't knock it back. would also take a frame to suit a tapered long travel fork.
OTHER INFO : This is an exhire bike (taped out name, logo will be removed before swap ) and has cosmetic damage to paint and paint on fork is pretty rough from transport, no dents to frame and fork and the staunchions are good and unscratched. The rear brake works but it needs to be replaced as it is notchy as fuck. This has an alfine 7 rear hub so there is no grubby derailleir to root around with, it was taken to the bikeshop and they adjusted the cable and the gears shift as intended. If you want info on Alfine hubs please google or pick my mind for the very little I know about them. The bike could do with a regreasing and such but I took it for a 10 k ride this morn and it seems to runs ok. The forks spring back and forth as intended I guess. The major parts are
charge duster frame, eccentric bottom bracket, made for alfine or single speed, med in size
recon race fork, qr
deore hydro brakes
alex dm 18 front wheel, qr
wtb speed disc rear wheel with alfine hub
PHOTOS : very shortly
recon race fork, qr
deore hydro brakes
