Frank has got one on his Fox 36. Seems to work ok.Anyone using one of these, if so how do you rate it?
Also, I am assuming it will fit a Marz Z1.....
Any other bolt on fenders that fit a Z1 that are worth a look in?
I've run one on my 34 for years, been so great now also have one on my 36. Had no issues with damage, even put itself back in shape after accidentally squashing it loading in a car.Anyone using one of these, if so how do you rate it?
It apparently fits but not perfectly due to the bridge.The Marzocchi fork has a very different bridge to the fox fork... Not sure it will fit properly.
They’re great but this is probably their weak point. Unlike the newer Fox fenders, or the classic Marsh Guard zip-tie style ones, they have no fixture to the fork lower and are cut well away from the stanchions so while they definitely keep shit out of your eyes, they don’t really keep it away from your dust wipers.Mostly I want it to keep the YYs quartz and granite stones off the stanchions.
McGoogle suggested RRP might also work? https://www.rapidracerproducts.com/products/mudguards/proguard-bolt-on.htmlAnyone using one of these, if so how do you rate it?
Yeah I had thought about machining up a bracket for a custom plastic whatever guard setup (no 3D printer unfortunately).McGoogle suggested RRP might also work? https://www.rapidracerproducts.com/products/mudguards/proguard-bolt-on.html
this could be worth a go?
A bracket that screws to bridge, and you cut n screw your choice of flat thing to it.. (am gonna test print it anyway)
View attachment 405604Mudguard for Marzocchi and FOX Forks by bwoo
Mudguard holder Fits: Fox 34, 36 Marzocchi Z1, Z2 You need M3 screws, threads are in the object. You can also resin print from ABS like resin. Enjoy!www.thingiverse.com
am printing a couple to see how it fits, happy to send some for you to play with (anon addy/PObox if you like )Yeah I had thought about machining up a bracket for a custom plastic whatever guard setup (no 3D printer unfortunately).
I will machine something up at some point, but need something asap. The amount of stones getting flung up into the stanchions by the pinner front tyre was cringe worthy last ride...
Opps yeah these RRP ones long is what I got not the mudhugger. Yes it works real well keeping small stones off the stanchions and definetly minimzes the dust on the fork seals thats why I keep the front mudguard on all the time. It fits well on my 29x2.6 tyre only downside is when little rocks/pebbles and small sticks go between the mudguard and tyre it sounds like crushing a coke can but you get used to it.McGoogle suggested RRP might also work? https://www.rapidracerproducts.com/products/mudguards/proguard-bolt-on.html
that's neat, as covers the tread from further away to control debris, rather than last minute blockingThese photos show how the plastic side thingys add some protection to the forks.
