AM The Andorran Endurobro
Lucaw
Next in line
I absolutely love my craftworks, but after riding it for 1 1/2 years, I started to wonder about a newer bike. After riding some mates bikes, I begun to notice some of the limitations of the crafty.
I started looking for some complete bikes second hand, but I saw this frame for a good price, and the guy included a pair of lyrik ultimates for a good price.
After a month long build, I present to you, my new bike!!!
Frame - 2019 Commencal clash race, size large
Rear shock - RockShox super deluxe r 230x65 (thank you @Isaakk
Front shock/fork - RockShox lyrik ultimate
Handlebars - 740 black bars, 35mm rise
Stem - truvantiv hussefelt, 40mm
Headset - across
Grips - Deity super crush
Saddle - Wtb
Seatpost -pnw bachelor, 170mm drop (thank you @yuley95 )
Front brake - xt m775, 200mm centerline rotor
Rear brake - xt m775, 200mm centerline rotor (thankyou @nathanm
Cranks - xt 175 mm (way too long, I need 165 or 170 cranks to ride this properly)
Chainguide - e13 top and bottom, with taco bash
Chain - sram 850
Pedals - blackspire nylontrax
Rear derailleur - microshift acolyte, clutched
Rear shifter - microshift acolyte
Cassette - microshift acolyte, 12-46
Front hub - dt swiss 370
Rear hub - foumula (hope pro 4 on the way
Front rim - raceface arc 30
Rear rim - spank vibracore (hope fortus on the way
Tyres - 2.5 assegai front, 2.3 minion dhf rear
Tubes - only in the rear
Total weight - yes
PJO
in me vL comy
It does pedal strike about every 4.5 turns, so it does need shorter cranks to be its best
Have you got your suspension firm enough or are you blowing through the rear travel?
Fantastic change from the previous bike!
Lucaw
Next in line
I haven’t bottomed out the shock, the cranks are just too long!
  • Like
Reactions: PJO
If you’re striking cranks that much, I don’t think 5-10mm shorter cranks will do much for you. Longer wheelbase long travel bikes with low BB’s require an adjustment in technique. Look at where you’re trying to pedal. My2c.
jrewing
175mm to 165mm will help loads. But yes technique too
Are you sure you aren’t running short shocked, Luca? You do have a bit of history with this.
If it’s a 29 fork, it should lift, but just wondering if previous owner compensated elsewhere with a shorter shock to balance out a mullet. Just throwing it out there.
Lucaw
Next in line
Yes, every bit helps, but if he’s striking every 4 to 5 crank rotations, technique is going to need to change even with short cranks.
it may have been a bit exaterated, but it strikes way too often
no, I swapped the 230x60 and now it has it has a 230x65 shock,
All good then. Sometimes there’s shenanigans that you don’t know about.
Comes down to technique then.
