cramhobart
Umm I think you'll find its only 1271m= 4194 ish? And the route you describe is well over 20km.
Alright, you got me on the finer details. I'll rephrase for you.Umm I think you'll find its only 1271m= 4194 ish? And the route you describe is well over 20km.
Climbing in 44/15 is certainly a challenge, however 6000ft over 20km is a veryAlright, you got me on the finer details. I'll rephrase for you.
Although the exact figures are not to your required detail, I think you will find that it does not detract from the difficulty of the challenge I formerly presented.
Ever tried climbing well over 20kms, '4194 (ish) ft' straight up on a 44/15?
Now the altitude and distance is more accurate, It dosn't really make it any easier now does it?
I'd say probably not. I posted up this link earlier in the thread. It's about knee problems caused by fixies but is applicable to single speed in many respects IMO. Probably better to err on the side of caution.mmm you got me browsing now , just had 2 cartlidge tears repaired and only have a single speed at the moment,while tears not caused by the bike riding ,is riding a single speed now good for me?this i must take into consideration.more googling required
No it's not. Resistance braking on a fixed gear bicycle is completely different from pedaling forwards in terms of physics and biomechanics - in that you have to overcome the force with which you are traveling forward by resisting the forward motion of your pedals before any braking occurs, which puts significantly more strain on your joints than pedaling forwards.It's about knee problems caused by fixies but is applicable to single speed in many respects IMO.
What a silly remark. Horses as a form of transport have been around a lot longer than cars but you don't see many horses on the freeway do you?use a sensible gear on your single speed? Cycling's been around for a lot longer than the derailleur
I guess we should all stop riding our bikes and get in cars too then. I don't see anyone in the tour de France not pedaling hard either. Of course you go faster up and down mountians with gears, no one's debating the factWhat a silly remark. Horses as a form of transport have been around a lot longer than cars but you don't see many horses on the freeway do you?
First of all, notice the hedging I used in my previous post. I never said 'riding a fixie=riding a single speed' so no need to get all uptight about it. It was this part of the study that I was referring to:No it's not. Resistance braking on a fixed gear bicycle is completely different from pedaling forwards in terms of physics and biomechanics - in that you have to overcome the force with which you are traveling forward by resisting the forward motion of your pedals before any braking occurs, which puts significantly more strain on your joints than pedaling forwards.
It's like saying that as it's been shown poorly aligned cleats on a road bike can cause serious knee injury, no one should use flat pedals in case you ride with your feet misaligned.
Dislike singlespeeds if you must but attributing knee damage to it from that study is spurious.
Now how is that not relevant to single speed riding?Across the board, it is universally accepted by medical experts that high-gear, low-cadence pedaling has a high likelihood of causing knee pain and permanent injury. The main preventative measure as well as primary remedy for that problem is low-gear, high-cadence riding, which is only possible with the ability to change to appropriate gears throughout a ride. Fixed-gear riders are unable to avail themselves of that remedy, and because of that, they experience more frequent and higher pressures on the knee than a rider on a bike with gears.
You're right, it was from a blog. But excerpts from studies say essentially the same thing. As in:snip
We're mountain bikers, so riding up hills is part and parcel of it all. If you're riding single speed, you don't have the luxury of sitting down and spinning on the steeper climbs. I'm not saying that you can't damage your knees on geared bikes, of course you can. But most of us "gearies" will change to lower gear when the going gets tough. It's all about being in the right gear at the right time.Excerpted from:
Knee Pain and Cycling
by Joshua Cohen, PT MS
Gearing choices can become an important variable in preventing the progression of chondromalacia patella. When the leg is forcefully extended, as during a cyclist’s power stoke, the knee cap acts as a pulley to transfer the large forces of the quads across the knee joint to the tibia (one of the lower leg bones). As a result, a component of the tendon forces pulls the knee towards the knee joint, greatly increasing the pressure on the back of the kneecap. This pressure can wear down the joint surfaces. Normally, a thin layer of slippery fluid lubricates the joint and prevents wear. However, during slow, forceful extensions (think big chainring grinding uphill) this fluid becomes displaced and the joint loses much of its lubrication. This is not good for your knees or pistons!
Keeping a higher cadence will help to reduce the pressure of the knee cap against the knee joint, allowing the lubricating fluid to remain between the joint surfaces where it belongs, and so lessening the risk of joint surface breakdown. Cadences above 80rpm are generally better for your joints than knee-mashing 60 rpm cadences. Remember to choose your gear inches wisely and take into consideration the terrain and your ability to power your gear to maintain a relatively high cadence.”
I said it's probably best to err on the side of caution and stay off the SS bike. What's your answer?mmm you got me browsing now , just had 2 cartlidge tears repaired and only have a single speed at the moment,while tears not caused by the bike riding ,is riding a single speed now good for me?this i must take into consideration.more googling required
What's your answer?
That's not a study either - it's yet another blog post. http://www.63xc.com/joshc/kneepain.htmYou're right, it was from a blog. But excerpts from studies say essentially the same thing. As in:
Fixed for you.That's not a study either - it's yet another blog post written by a guy with some important letters after his name that signify that he knows a lot more about knee damage and cycling than a bunch of dudes on a mountain bike forum.http://www.63xc.com/joshc/kneepain.htm
My point is it turns out your "study" is a blog post of a blog post of a blog post by a personal trainer with an unspecified MSc degree - and therefore an opinion rather than any sort of study.Fixed for you.
