Plankosaurus
Spongeplank Dalepantski
Damn straight! You're not living if you're not risking terminal thread damageI have used an impact gun.
I'm not going to say it but they probably had fun in their own mind
No...unless you have a gaping gash, the air inside will need to be at a certain pressure to force it's was out of the hole/leak. Once the internal pressure of the tyre is lower than the required amount of force the tyre will stop or significantly slow down deflation.It's strange that it doesn't deflate past a certain point though isn't it?
Unless riding.No...unless you have a gaping gash, the air inside will need to be at a certain pressure to force it's was out of the hole/leak. Once the internal pressure of the tyre is lower than the required amount of force the tyre will stop or significantly slow down deflation.
Which would add pressure...Unless riding.
And cause more leaking.Which would add pressure...
You probably already know it, but it sounds like it might need another wrap of rim tape to make the tyre bead seat tighter on the rim.I have recently been experiencing the opposite problem, holds at anything above 20PSI, deflates once lower and is a PITA to reinflate. The higher pressure holds the rim tape, bead etc. or whatever other sealing parts down into position.
Don't worry, I'm taking the tyres off to inspect sealant levels and rim tape this weekend.
Had this at work, apparently it's not obvious that a higher durometer rubber seal gland doesn't seal well at low pressures.. On emergency gas isolation valves..
And get flatter.And cause more leaking.
Inflated tyres are so cheugy.And get flatter.
Low psi is very on trend.Inflated tyres are so cheugy.
Ok boomer.Low psi is very on trend.
I am one of many pulling Santa's sleighOk boomer.
