Post up some pics of the bearing. Is the seal failing and shit is getting in?Exactly. Just added up the kms, 1700 kms and 4 months since last replaced. It’s one particular pivot, maybe an alignment issue?
I’m completely over it
You actually want the 668 Enduro Max bearings https://cycling.endurobearings.com/products/688-llu-max for that or the equivalent NTN/SKF full complement bearings.I didn’t take a pic when I opened it up last week but this is from the last time in June. Essentially looks the same, fully stuffed. Spacers are all intact.
I’m not tooled up to replace bearings myself, the shop I take it to I completely trustIf it pivots smoothly and easily without the shock in place that will give you a good starting point. Then see if you can twist the triangles relative to one and other.
Bearings snug in frame?
Have they offered any suggestions as to why this may be happening?I’m not tooled up to replace bearings myself, the shop I take it to I completely trust
They suggested what I wrote above. The bearings only measure 16x8x5, with the exception of the MP, and are mostly pressed in to raw carbon. Wouldn’t take much side loading to make a mess.Have they offered any suggestions as to why this may be happening?
I have only had pivot bearing issues (on a pivot funnily enough) once on a second hand frame. The replacements solved the issue.
Japanese bearing co? I didn’t have much choice as I want to get riding again asapWhat brand bearings did you get?
Bearings ain't bearings unfortunately...Japanese bearing co? I didn’t have much choice as I want to get riding again asap
You really know how to cheer a guy up.Bearings ain't bearings unfortunately...
I was once in a similar pinch and bought Japanese "KSM" bearings for a wheel... Got 2 weeks out of them before they flogged out... The NTN that replaced them are still going years later.
The worst part is I knew they'd be shit and hated myself for buying them...
Sorry mate,You really know how to cheer a guy up.
I really am over this nonsense. It should be nbd
