The Duckmeister
Has a juicy midrange
Don't do it, it's fucking revolting! (as I found out in a Fuckwit Confession way......You know tomorrow i'm going to put salt in my coffee... And then totally regret it![]()
This one?
it was on ABC in the afternoon when i was a kidOnly us Pommes/Irish would know that one.
So you've met the ex then...That sounds far better than a hot salty bitter latte....
Probably need something like this @pink poodle (just note there is some different variants depending on what chain you're running...):There is going to be plenty of these! But to kick off my brave new world questions:
Can I run a shimano saint crank with SRAM gx/nx 12 speed drive?
73mm bottom bracket and 148x12 rear hub.
104 BCD Chainrings
104 BCD chainring for SRAM and Shimano Drop-Stop wide/narrow sprocketwww.wolftoothcomponents.com
He best get a 31 tooth as a compromise between 30 and 32.Probably need something like this @pink poodle (just note there is some different variants depending on what chain you're running...):
104 BCD Chainrings
I was really impressed with it on the Revel Rail I reviewed on here.Anyone have any experience with Canfield Balance Formula suspension they would like to share?
Yep it’s very much a magic carpet ride. Kind of sits halfway between Horst link and DW-link for most metrics. Tends to eat bumps well without being too compliant.Anyone have any experience with Canfield Balance Formula suspension they would like to share?
Just remember you're on big wheels now, smaller front ring to compensate lol.32 is where it is at. I'd go 34 if they still fit on frames!
That's a wide/narrow, not a narrow/wide... The tooth timing will be out of sync.Probably need something like this @pink poodle (just note there is some different variants depending on what chain you're running...):
104 BCD Chainrings
