Kit I linked to seems to have a screw in nipple to connect a bit of bong hose and syringe to.If this is them, they don’t have bleed nipples.
https://bike.shimano.com/en-AU/product/component/shimano/BR-MT400.html
Resin/organic pads usually need more frequent sandpapering than metal because they're more prone to glazing.Sorry I have asked this before and tutorials don't make a distinction but can you sandpaper organic pads or just sintered ones?
Is it possible to cook the glaze into an even harder finish?Resin/organic pads usually need more frequent sandpapering than metal because they're more prone to glazing.
Cooking glazed pads is totally pointless, because the glazing is caused by overheating. "Contaminated" is more often than not a misdiagnosis for glazed pads.
It’s easy yo see if they’re glazed. I assumed people could see this. It’s a silly assumption.Resin/organic pads usually need more frequent sandpapering than metal because they're more prone to glazing.
Can I substitute in glacé for glaze, it would appear that I'm all out.Is it possible to cook the glaze into an even harder finish?
Probably cook the whole pad thickness into a uselessly hard compound if you tried just a little bit....Is it possible to cook the glaze into an even harder finish?
Most people seem to presume that lots of noise + minimal friction = contaminated, but more often than not it's just glazing. However if the brakes have really been overcooked, the rotors can be affected too, and there doesn't seem to be a reliably effective recovery from overdone rotors.It’s easy yo see if they’re glazed. I assumed people could see this. It’s a silly assumption.
Well now I'm thinking toffee pad, high sheen finish, and a little brandy flambe to set it all off. Served in a pool of caramel cream and topped with an assortment of glace fruit.Can I substitute in glacé for glaze, it would appear that I'm all out.
A few pages back I asked pretty much the same thing. There are some dodgy SRAM ones around, but ODI don't make any 90mm anymore.Is there such a thing as a replacement 90mm grip for kods grip shifter? Beyond ebay $5 versions that qill wear out before ive finished installing them?
Am i better off cutting a spare pair of lock ons? Will they stay put with only the outer ring on?
All turned into computer chips. Or tits.What about those silicone grips that were very trendy 40000 years ago?
Looks at silicon grips on bike, keeps mouth shut.All turned into computer chips. Or tits.
Much better use.All turned into computer chips. Or tits.
I still rate them as the most comfy for my mits.What about those silicone grips that were very trendy 40000 years ago?
