It's all about retro, get with the times maan!When did double denim become acceptable? I say never, but it is everywhere!
Its offending my highly sophisticated sense of style...It's all about retro, get with the times maan!
Is that what passes for irony in Newcastle?Its offending my highly sophisticated sense of style...
We only do sarcasm, irony hasn't made it here yet. I'd wager it will catch on at the tail end of the trend or just after it fizzles out.Is that what passes for irony in Newcastle?
Too close to the sea for irony in Newcastle - it rusts.Is that what passes for irony in Newcastle?
This might work.Anyone know if it's possible, and how to do it, to repair a garmin .fit file? Mine decided to miss the first 45min of gps data today but record all speed, cadence, heart rate etc. Was wondering if I can use my brothers gps data to fill the blanks?
Uncle runs a company that taps into the methane build up from land fills and puts generators on them for power.Also given we are at war with accumulating huge piles of garbage at the moment and that those huge piles do produce greenhouse gases and pollute the land and water ways as well, is there a reason we don't just build some massive incinerators and trap the heat based energy? Is one significantly worse than the other? How does it compare to fossils? I suspect we have a pretty solid supply chain...
A hippy I once worked with had something like this running from his thunder box, he said you can buy them as a kit. I've also heard of it being done at the waste tips in Cairns.Uncle runs a company that taps into the methane build up from land fills and puts generators on them for power.
That's what the last bloke said playing golf in a storm, not sure if he got to see the outcome.I am developing lightning capture and storage. It is a black art. Well everything turns black.
Air compressor with fine tipped nozzle to get under the gripsSpeaking of sealant, does Orange Seal mix well with Stan's? Bike came out of the shop with Stan's but I've got Orange Seal in the shed.
Also, what's the best way to get foam grips off then back on again?
Take them off with a knife and fit some good grips insteadSpeaking of sealant, does Orange Seal mix well with Stan's? Bike came out of the shop with Stan's but I've got Orange Seal in the shed.
What sort of knife would you recommend?Take them off with a knife and fit some good grips instead
Don't use the one that has brown streaks eventhough it is sharp.What sort of knife would you recommend?
