気が狂っている男
It must have been difficult to decide the fate of that knife after the incident.Don't use the one that has brown streaks eventhough it is sharp.
Yeah, it'll happen, but it's three days old, I'm not read...... Sorry, my wallet's not ready for that just yet.... .Take them off with a knife and fit some good grips instead
Funny, I grew up with a 'poo' knife.Don't use the one that has brown streaks eventhough it is sharp.
Hairspray. It works as an effective enough lubricant when it's wet, then sets to act as a mild glue. To get them off, gently work a long flat screwdriver under the grip, squirt a bit of hairspray into the gap & slide the screwdriver around the bar to unstick, then just slide the grip off. To refit, lightly spray the inside of the grips, slide on & leave a few hours to set. Don't go to heavy with the spray for refitting; the more you use the longer it'll take to set, and the grips will slip on the bar. For the same reason, don't put the grips on & expect to ride straight away, because it does need a bit of time to stick.Also, what's the best way to get foam grips off then back on again?
Hairspray is great for grips. Never need anything else.Hairspray. It works as an effective enough lubricant when it's wet, then sets to act as a mild glue. To get them off, gently work a long flat screwdriver under the grip, squirt a bit of hairspray into the gap & slide the screwdriver around the bar to unstick, then just slide the grip off. To refit, lightly spray the inside of the grips, slide on & leave a few hours to set. Don't go to heavy with the spray for refitting; the more you use the longer it'll take to set, and the grips will slip on the bar. For the same reason, don't put the grips on & expect to ride straight away, because it does need a bit of time to stick.
Run the pointy end under the grip around the bar and spray some soapy water in there at the same time. Then you turn the grip and it slides off most of the time, you do get some stubborn ones from time to time. It's not one of those tiny hose picks, the shaft is actually quite long.Ok, so what do you use a hose pick for?
It must be, I've heard about this fashion thing too but don't understand it. We should all wear white ponchos and make it easier for everyone.Is this fashion?
Radiator hose removal, or o rings (smaller picks) or nose rings or a Prince Albert. Not to be confused with a packing removal tool.Ok, so what do you use a hose pick for?
I don't have a clue but my stupid question is, what is she hiding under that bag ?Is this fashion?
Is trend.Is this fashion?
Me, I'm new here.....No doubt I've missed this somewhere in the few years I've been away, but what happened to post counts, or Member Since dates? Without these, how will I know who to ignore?
