fjohn860
Alice in diaperland
Got a $6 pint at Northies tonight.I think it already started here when they averaged a pint at $18. No wonder why the young kids would rather snort some crack.
I'll take that as a win.
Was that 98?Got a $6 pint at Northies tonight.
Steps has a different bolt pattern to ISCG or ISCG5.Van this thing be mounted to an iscg05 and used with a normal bike? Or is it actually eeeeb specific? I'm chasing a cheap top guide. I'm sure I have 3 but fucked if I can find them.
Water Pump Gasket Slotted Hole - For R33 GTS RB20E Skyline | eBaySteps has a different bolt pattern to ISCG or ISCG5.
I had to cut the 3rd bolt hole off a bottom guide, do a bit of reaming with a dremel and make spacers to fit an ISCG5 to my Bosch.
Like we need more bolt patterns
Ali ?Well that sucks. I finally find a chain guide that seems a fair price for such a simple and small piece of crap, and...well that is inconvenient.
I have one of these in the spares box I can send for postage cost if keen @pink poodleAli ?
6.36AU $ |1x Mtb Chain Guide - Iscg 03/05 Bb Post Mount, Wide Narrow Gear Guider
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
Ali ?
I bought this one. Then cut the top guide and bash off to make it fit. I only needed the bottom pulley anyway as I already had a top guide.
27.05AU $ 32% OFF|Mountain Bike Pulley Chains Stabilizer | Mtb Chainring Protector Plate - Iscg05 - Aliexpress
I don't think so, if its like cars then it absorbs water from the atmosphere over time and changes the boiling point.There is no other place on the forum for this question..!
I was bleeding a set of brakes last night. The shimano mineral oil in them was grim! Anyway I grab my trusty spent oil jar and as I am about to pour the black filth in I see the oil (which hasn't been touched for quite a while) is clear and all the good has sunk to the bottom. Can this oil be filtered and reused? Can it be reused just from sitting long enough to clean itself? Or is it a case of once spent always spent? I have plenty of fresh shimano mineral oil, but one gets curious from time to time.
DOT fluid (glycol-based) absorbs water, mineral oil generally not.I don't think so, if its like cars then it absorbs water from the atmosphere over time and changes the boiling point.
Although I am not totally sure when it comes to MTB brakes and the braking force compared to that of a car.
I keep seeing videos pop up of Milk and other things used in place of brake fluid and most seem to do okay.
I do wonder if you could get a brake fluid checker from repco etc for a handful of dollars and if it would show up as 'bad' considering its such a small amount, maybe the time hasnt done it good. Would be interesting to hear your discoveries.
They do regenerate hydraulic oil on a professional level but I'm not sure what's involved. It costs a fair bit to do properly as it requires intensive testing.I've done the baby oil before in a pinch @danand it was geat. I was out of the authentic so loaded up my brakes and you couldn't tell. I did a few big long rides (sawmill in the Watagans for locals) and the brakes were as good as any other time.
I was thinking a filter like a commercial kitchen might run their fryer oil through. But a long sit then decant gently could work as well.
The neighbours might think you're running a meth lab but @pink poodle could always set up some coffee filters from work.does the oil in bike calipers even get that hot? (virtually no shear like is in hydraulic system)
not much in SDS that can easily test and little other data available... but not that critical? just separate the solids..
Yes it did. There's massive shortages due to drought in Spain. That doesn't explain why Cobram's has gone up 40% though the chunts.Did the price of olive oil kind of double over January to April?
