I'll bet you don't! Are you the guy who has the P2/3 who made the other thread about a threaded steerer tube?As you guys might or might not know i have a truvative holzfeller stem which seems to thread on instead of dropping right onto the fork steerer.
Would it be ok to use this type of threaded stem on a normal fork steerer which does not have threads?
thanks
ya same guy hereI'll bet you don't! Are you the guy who has the P2/3 who made the other thread about a threaded steerer tube?
Does it have pinch bolts on the back? if so, I'd hazard to guess it's just a bit tight, and you should be able to just push it on, you may need to loosen it off entirely and spread it open gently with a flat screwdriver...
Check that there's no damage to the top of the steerer as well. If you banged it with a hammer (much cheaper than therapy), then there may be a small metal 'lip' on the top that you'll need to carefully file down before the stem will slide on.Does it have pinch bolts on the back? if so, I'd hazard to guess it's just a bit tight, and you should be able to just push it on, you may need to loosen it off entirely and spread it open gently with a flat screwdriver...
