Twisted&Broken
Wombat. The tension wrench is new. Bought yesterday to check these bolts. It was 2to2.5 turns of the bolts under the required torque. I can't get a torque setting but by feel it was pretty loose.
Cool, my point was that it seems odd that you'd crack something with 4Nm, unless that something that in the wrong place, or clearly not meant to take that sort of pressure.Wombat. The tension wrench is new. Bought yesterday to check these bolts. It was 2to2.5 turns of the bolts under the required torque. I can't get a torque setting but by feel it was pretty loose.
Ahhhh, fair enough.I don't think the trim cracked from the tention put on the bolts. I think it is from the rubber deforming.
Or just ride your bike to the location you want to ride?Your only non-loctite solution here is to buy a ute.
Its a wagon, just put them in the backOr just ride your bike to the location you want to ride?
It takes longer to get the bike racks off with the wrap around brackets than it does with the T bolts so I'd just use them.So here's the latest update.
Thule rep came out a week ago and replaced the whole roof rack system with a new one as they have no idea why they keep coming loose.
They replaced them with a new model wingbar. It's the latest and greatest, quieter,etc,etc.
He fits them up and then goes to put on my bike racks and the wrap around brackets don't fit. The bars are to wide. He wants to fit them using T bolts but I need to be able to easily remove the bike rack as I put a kayak on the roof and don't want to have to pull apart the racks to remove the T bolt every time.
Not a problem he said. I'll post you the wrap around brackets.
Well a week later I get an email. The brackets aren't available. So now I can't attach my bike racks.
This is becoming a bad joke.
Disagree with the tacking the T bolts in and out being a pain as you just loosen them off a little and slide them out the ends still attached to the bike rack - well you do on the sets I have. Putting the rubber in is pretty effortless too (in my opinion).Turner.
To take off the bike rack maybe. But then there are bolts sticking up.
To take the T bolts out and put the rubber back is a pain.
I'm seriously thinking a refund and another brand could've the way to go. They have been helpful but also frustrating.
