No worries. What shock are you running? Is it a DHX RC4 or DHX 5? If its an RC4 you could probably get away with running a 300lb spring or a 325. If its a DHX 5 stick with a 350.[HR][/HR]Thanks mate....
The leverage of the bike can also make minor changes in spring rate, the V6.0 one that I use explains the changes further down the page. I also use the TFtuned one as a secondary check.No worries. What shock are you running? Is it a DHX RC4 or DHX 5? If its an RC4 you could probably get away with running a 300lb spring or a 325. If its a DHX 5 stick with a 350.
