If the lever blade is loose and wobbly (common problem with hayes over time) it could either be the small black pivot bushings needing replacement, or if you look closely the pivot hole [not sure of actual name] in the lever blade (where that round thing is with the grub screw through the middle- that pushes into the master cylinder) could be ovalised - in which case, you can't do a whole lot....
