discofrank
and very very very fast
It was designed and built in the 60’s using slide rulers. Large panel gaps at sea level to account for panel expansion at Mach 3 speed runs.It was pretty cool getting to walk around one. Surprisingly home built and rough looking up close!!
most fast air frames have gaps...they piss all over the ground when sitting on the flightline!Large panel gaps at sea level to account for panel expansion at Mach 3 speed runs.
Sort of but not quite. Different materials have different inherent properties and behave in different ways. Aluminium in its pure elemental form is light, but not exceptionally strong, not particularly stiff, nor very springy, and has a particular dislike for repeated flex cycles, weakening every time it bends. Therefore it is alloyed with various other elements to improve particular characteristics, but it still has a fundamental dislike for cyclic stress, so stiffness is often a focus for durability, sometimes at the expense of comfort.Why? Ti is very strong and very light. Theoretically you could make bars much lighter than aluminium by making them thinner. Still as strong or stronger but deflection is independent of material strength and only dependent on section size so if it is thinner it will flex more. If the thickness is the same as aluminium the flex will be the same and the bars still lighter but material properties are such that it transmits more vibration. This I am guessing since I dont have solid data just my observations but it is possible due to the stronger material properties. My Muru Ti frame is very light and thin and it is flexy.
Yeah funny" the fastest guys on the block ".It was pretty cool getting to walk around one. Surprisingly home built and rough looking up close!!
Such a great story and so well told. There's always someone faster...It was pretty cool getting to walk around one. Surprisingly home built and rough looking up close!!
The White Bros titanium bar from the 90’s was nice I thought.
