No torque on a press-fit BB. :wink:
However, chckt the crank bolts; if it's Shimano, loosen the two pinch bolts through the butt of the left crank, then check the end cap. It should only be firm enough to remove lateral play in the crank - too tight will overtension the bearings. when the end bolt is good, tighten the pinch bolts to 14Nm (some cranks are specified at 15Nm max, but 14 is more common).
If it's SRAM, crank the assembly bolt up really tight, 'cos they do have a habit of loosening off.
Then go & check your headset. 99% of noises in new bikes that get blamed on bottom brackets are actually headsets settling in & slackening off a bit.
