Small cars are fun.I feel a bit dirty. That's the first Corolla I've ever wanted to own.
Oh hell yes. A fact I never fully appreciated until I replaced my 2L 5spd 1984 Bluebird with a V6 auto VT Commondore.Small cars are fun.
I’ve found modern corollas to be pretty decent steers even in povvo pack rental car trim. Of course that could be the whole “rental cars go better” thing at play…And the ecu has been cracked. Easy plus 50kW/60Nm on the 200kW map.
Corolla will be the standard chassis and suspenders so no bespoke stuff but still should be decent.
My 1969 Reno R10 with the 1100cc engine slung out behind the swing axle rear suspension was a riot. Scary, but funSmall cars are fun.
Sometimes I miss the KE70 I had. Poo brown for bonus points!
I do not miss the ca18de reliability though. Fun engine, when it worked. BraaaaaapbraaaaapPOP
Bluebird small?Oh hell yes. A fact I never fully appreciated until I replaced my 2L 5spd 1984 Bluebird with a V6 auto VT Commondore.
Wasn't it the first four-cylinder limousine?Bluebird small?
Well, mid size to be fair. But 5sp, rear wheel drive and not enough power to get in to serious trouble. Was my first car, is it obvious?Bluebird small?
Was one of theseWasn't it the first four-cylinder limousine?
My Dad had a Bluebird 2L wagon with an auto. I borrowed it a lot when I first started to drive. Had the chrome roof racks, the stickers and the pin stripes too.Well, mid size to be fair. But 5sp, rear wheel drive and not enough power to get in to serious trouble. Was my first car, is it obvious?
That is the one.Was one of these
and NZ iircWould be extra cool in wagon version… They still make a wagon for the European market.
Yep, and my i30N with 202 is still a load of funBut 220kw!
A modern corolla Weights pretty much the same as a VL according to google.220kw! I had a VL Commodore with a 180kw RB30DE in the 90s and that was nuts. But 220kw! Even the famous TRD 4A-GE didn't make that much.
I had an argument with a True Bogan I used to work with. He owned an AU Falcon, my Kingswood was still on the road. He could not get it through his thick skull that my Kingy Wagon weighed significantly less than his AU sedan. Just couldn't comprehend that all the mod cons added a significant amount of weight. When I pointed out if I could get 'just' 220kw out of the 4.2 V8 in the old girl (which wouldve been easy), then I'd be able to embarrass Clubsport owners, he decided he needed to end the conversation.A modern corolla Weights pretty much the same as a VL according to google.
VL is 1250 to 1350kg, corolla is 1220kg.
Anything that has a 4A-GE will probably be under 1000kg
