Track pump for tubeless tyres - recommendations?
The Duckmeister
Has a juicy midrange
Depends on both the tyres and rims and their respective variance from ISO-spec diameter more than the pump. Any track pump will seat tightly-toleranced tyres and rims, but if there's any loosemess even the best track pump won't cut the mustard. The various high-pressure stored volume tank-type pump things are a bloody good thing, and will often seat tyres that a track pump won't do, but they're not failsafe, and some particularly loose fitting tyre & rim sets will still defeat them.
There are two types of these things, integrated pump and separate pump. The integrated units are great if you don't already have a track pump; flick the outlet gate one way and it's open so the air you pump goes straight through the reservoir & into the tyre, or flick it the other way to close the outlet & you pump up the reservoir to high pressure, then open the gate to deliver a quick blast of air to the tyre.
If you already have a track pump, the non-integrated tanks are the way to go. Close the outlet gate, connect your pump to the inlet valve, and from there it's the same as above..
Lazmo
Old and hopeless
maybe just buying a compressor is an option... it'll do a bunch of other handy things too
richie_gt
Have a compressor already, it's big, old and I think it's not running right. At least I can pack the track pump into the car if needed.
