macca_1972
Hey all,
I have been stripping down my '08 Trance for a rebuild and have run into a problem trying to remove the lower shock bolt. (Indicated by the silver pick tool in the picture below.)
I have been trying everything I can to get this sucker out but it is stuck fast. Admittedly it has been in there for around nine years now without being removed. I have doused it in WD40 for two days, tapped with a mallet and socket drift (with a socket underneath for correct support) and also used the sockets with a g-clamp, all to no avail. I am at the point where I feel that applying any more force than I have been will end up cracking or damaging something.
The shock, spacers and non-drive side bearing inner race (pointing at the camera) all rotate freely around the bolt with no binding, which leads me to assume that its the inner race of the drive side pivot bearing that is stuck fast to this bolt. I have spoken to a couple of shops and they can't think of anything they would do beyond what I have already tried. I am starting to wonder if, as an extreme measure, the bolt needs to be drilled out to remove it and replaced with another one.
Has anybody experienced something similar to this? I'd be keen to know how it was tackled and what the outcome was. Many thanks.
