Ok will do. I can't wait to see what the LBS wants to sting me for those.try it "as is" with tubeless valve and some sealant. worked fine with my dt rims.
if it leaks to much then just rip that rim tape off and put some 3M reinforced tape on (like come with stans kit) and should be right.
I ran Specialized Fast Tracks tubeless on DT 445D rims and had no problems with them, after some initial teething issues. Although if your gonna go to the trouble of switching to tubeless I would use new or near new tyres. That way you dont end up having to fit new ones a month or so down the track.I was wondering how the Specialized tyres hold up, The Geax did not leak anything through the side walls at all, no sealant has come through and they stayer inflated without sealant.
I run as low as 25 psi with tubeless, but I only weigh 55kg. i get a bit of burping, but i check the pressure during the dayWhat sort of tyre pressures are people running for downhill? In the past I have been riding some tracks with pretty aggresive cornering and burped it here and their. Dont really want to be mucking around with pressueres to much, I definately hate my tryes firm, absolutely no traction I would rather roll slower. I was thinking around 28/30 front and 30/32 rear?
I'm in the process of swapping a front wheel to ghetto to try it out.There are many variables which will dictate what sort of pressures any given rider can get away with running. (hang on, I seem to recall saying this a fair few posts back)
You need to take into account:
Rider weight, which in my opinion is one of the most important factors
Riding style - Do you flow and look for smooth lines, or are you Mr.Plow and destroy parts on a regular basis
Rim/Tyre choice
Me, well I'm 68kg, I'd call myself a smooth rider, and I know what I can get away with using my rim/tyre choice - Mavic 823's & 2.7 Highrollers F&R
I run 25psi front, and 27psi rear. I could go 25psi rear, but run 27psi on rockier terrain (DH).
For all those concerned about burping tyres, you'll have more chance of noticing the extra weight of a fly on your helmet, than you would the minuscule amount of air lost due to burping - Get over it!!!
.........Shorerider.
I reckon the rear will be OK, the front might be a bit low depending on your rim. Different rim shapes and outside diameters give different levels of support to the bead. The risk is at that low a pressure you pull the tyre bead away from the rim with a side loading eg a corner, dropping off something, and produce a big enough burp to completely lose all your pressure. I did this on a XC ride a couple of months ago, went off a little step about half a metre and landed with the front a bit sideways, pulled the tyre off and it was game over, 20 minutes to clean up the mess and fit a tube. I suggest you start with a bit higher pressure in the front, then work your way down towards your target pressure. And carry a tube and a rag for if/when it all goes wrong!I'm in the process of swapping a front wheel to ghetto to try it out.
I weigh 66 kgs + pack (4kgs) and ride a duallie with standard 2.1 Nevegals.
I run on mostly rocky ground pressures from F 21 - 24 psi and R 25 - 27 psi. I've had 3 pinch flats in last month.
I'm older than most and ride fairly slow compared to racers but pick my lines and ride smoothly also.
I realise this is "how long is a piece of string" question but am I able to run my 20-21 F and 24- R pressures with this tubeless setup?
I'll be using the standard Nevegals, Stan's as the goop and split tube.
Cheers
I love the simplicity of this approach and am wondering what other experiences people have had simply by taping the rim and using a tubeless valve?After using homemade Stan's-style (ie inside the rim) rim-strips for some months with no drama (I have already posted the method on this thread) thought I'd give "homemade Stan's yellow tape method" a go. This is the ultimate tubeless conversion imho; easiest and cheapest to do, easiest to fit tyres, and lightest weight. So, here goes..
1. Remove old rim tape.
2. Replace old rim tape with adhesive "filament" tape. I used 3M strapping tape (available at bunnings, etc for under $10) as it is the same one used by NoTubes, but another brand will do. For XC rims use 18-19mm width, for most wider rims go the 25mm option. Make sure it is tightly applied, and as smooth and even as you can get it.
3. Use a knife and round file to very carefully cut out a hole for the valve to go through.
4. Fit a tyre and tube, inflate for 24hrs at 50-60psi. This helps to fully seat the tape and make sure there are no air bubbles/gaps etc.
5. Deflate and remove tube.
6. Get an old tube and cut out the valve, leaving a piece of rubber attached about the size of a 5c piece. This is your tubeless valve (much cheaper than Mavic ones!)
7. Screw the valve in nice and tight to get a good seal on the rim tape. If you want you can get a small o-ring from the hardware store to put on the outside of the rim so you get a double seal and the valve lock-nut doesn't scratch your rim.
8. Fit tyre (adding your choice of sealant), inflate with a compressor (occaisionally a foot pump will work), do the sealant shake, and away you go!
I have successfully done a tape-only conversion on XM317s and non-UST crossmarks. I used one wind of strapping type tape (3M brand), followed by several winds of standard electrical tape. The extra electrical tape was needed to "pack" out the rim and make a tighter fit for the bead. Valve was a from an old tube, cut down to a small stub and screwed down tightly. Sealant was a homemade latex-water mixture. Inflated by compressor with soapy water sprayed on.I love the simplicity of this approach and am wondering what other experiences people have had simply by taping the rim and using a tubeless valve?
I'm keen to convert my second bike to tubeless (main bike is already running tubeless but it was dead easy because i'm running UST rims and tyres). FWIW the rims I want to convert are XM317's and run UST Ignitors.
The 317's are pin jointed and I assume they will leak at this join. Will this stuff it up for me?
And if this method works, what is the point of using rim strips?
I guess they reduce the load on the tape which might improve reliability. But I'd think you would be able to come up with a tape that's sufficiently strong enough. The cynic in me thinks it's a lot easier to sell two rim strips for $100 than a roll of tape though....
