Not sure why your having probs with any of the setups you've got. The way I set mine up is as follows:
You'll need a small container with some dishwashing liquid and a small amount of water in it just to thin it out, 2 cups of stan's sealant per tyre and a compressor.
1) With the rim strip/tape and valve in the rim, mount the tyre and use your finger to run the soap round on the tyre bead, you don't need heaps, just enough to allow the bead to seat easily.
2) Use the compressor to inflate tyre to the max pressure stated on the tyre, check the bead is fully and evenly seated around the rim. Leave inflated for around a half hour.
3) Deflate tyre, pop 1 bead off the rim and lever a small section off the rim, I like doing this on the opposite side to the valve so you don't get sealant in the valve straight away. Pour 2 cups of sealant in the tyre and mount back on the rim. Inflate to max again and hold rim on it's side to allow the sealant to flow round the bead. You can leave them as long as you want on each side, but around 5 min is all that they really seam to need.
4) Install wheels on your bike, set tyre pressures and GO SHRED!!!!!!
I have used this method on all my setups, and my dh bike went a month in whistler with no flats! Always bought a smile to my face when passing people changing tubes on the side of the trail, hehe!
