thewayweroll
Squid
Sealant will be ok till tomorrow .
My Geax Gato`s were a bitch to do . Number one they were a nightmare to even get on to the rim snapping 2 tyre levers . Getting them to seat was easy enough with the dishwash bubbles but for some reason could not push the sealant through the stem . Cracked bead added sealant and sat at the servo with sponge dishwash liquid and rag and soaped my way to happiness . Once inflated spin tyre in your hand then set to horizontal and move up and down rotating the wheel . Then i stamped the wheel against the ground whilst rotating and all good . Set up my spare wheels on Kenda Dred Treads easy as , guess it depends on the tyres ?It's a deore xt rim running a Geax Goma tyre. It seems like its around the bead. It's like I said. Its as if I can't get enough air in it to get it to 'pop' so to speak. I must have got lucky with the rear...
Compressor makes it so much easier, I like to put the clear plastic tube over the valve and with an air gun attachment pump it up. Really easy to do then. Definitely worth the effort.Thanks guys. I only have the one ust setup so no real use for a compressor ( Although I'll need an adapter I'd say to go from Schrader to presta....) But there's a couple of compressors at work. I might try your extinguisher trick though. I have an old extinguisher at work.
Hi Muzspeed,I put a new Rubena Kratos on a DT Swiss tubeless wheel to replace a rocket ron . The tyre was easy to get on so i just put some sealant in and then inflated to around 45 psi ran the sealant around and then adjusted to my liking - the old squeeze with your hand trick . It seemed to pop in well and has stayed inflated but todays ride it seemed as if it wanted to burp and had some sealant coming out from between the rim and tyre . Have i missed a crucial step or is this normal ? I have experience with doing the rim strip conversions and apart from rolling a tyre off due to stupidly low pressure have not had any issues . These are my first full tubeless wheels . If it makes a difference they are 26 " .
