I've got a wire bead Larsen and Crossmark on XT rims w/ Stans at the moment.
I haven't used UST tyres so I have nothing to compare them too but I've had a puncture and it sealed straight away. Mine have held air well. I've only pumped them up a bit once in the last month.
Definitely get a compressor. I managed to seat mine with a track pump but it took 4 hands and a lot of swearing
Depends how heavy you are. If you have some serious kg's I would stay with the tubeless tyres. If not, reap the benefits of a lighter tyre.
Just dont put more than 50 psi in them, its not much fun
My dad has run a nobby nic and a racing ralph tubless. They took a bit of effort to bead in but once they wer up they were fine. Only problem is the side walls are very thin and therfore rip pretty easy. My dads now runninf them with tubes because hes ripped the side walls.
ive used ust rims with standard tires for years now.
my dad runs standard nobby nics on ust rime and it wroks great, has never had any problems with it.
I am doing the same thing at the moment with Maxxis Monorail standard tires with no problems.
If you ride smooth and rarely get sidewall slashes then go for it. You may need to up the pressure slightly though as the thinner carcass is more "bendy".
I'm running Schwalbe Smart Sam tyres on Mavic UST rims with Stans sealant.
Tyres are Sport versions (wire bead). It was ridiculously easy to set up and have had no problems what so ever. They rock!
