Useless v-brakes are useless..
Coopz
I bought an Avanti flat bar road bike recently that wasn't ridden for a few years. Replaced a few parts and have it a good clean up and it looks like new but the issue I'm having is the front brakes. They barely work and I'm running out of ideas.. I've tried the following....
-Cleaned the rim with alcohol, simple green, brake cleaner, holy water, only made a minor improvement.
-replaced the pads, reseated the pads, no real improvement
-cleaned and oiled the cable, triple checked the tension.
The brakes feel strong and engaging with the pinch force they just won't bite. The rear brakes work fine though.
My wife has a similar spec road bike with Tektro vbrakes and it stops like its got 4 piston calipre hydraulic discs...
Jrok
Did you allow for toe-in? I put a cable tie on the leading edge of my brake pad when setting them so they grab nicely and dont squeal
Sent from my Redmi Note 8 Pro using Tapatalk
Labcanary
One potato, two potato, click
Are the rims and brake pads the same front and back? Not all braking surfaces and pad materials are created equal. Cheaper pads are often a harder compound and feels like you're braking with wooden blocks. A softer pad compound will brake much betterer (but also wear faster).
ausdb
Being who he is
Plus one on the cable tie for toe in. I just tape two thicknesses of business cards to one end myself. But if it's old and hasn't been ridden for a while the pads may have just hardened up with old age. Maybe time for new pads?
Try high quality brake pads on it and roughen up the braking surface on the rim, also check that someone hasn't changed the brake levers or calipers to an unsuitable match.
Coopz
I bought new pads for the front and back, I just tried switching them over and it's a noticeable improvement in braking. Still not amazing but at least the bike is safe to ride now. Think the pads I bought on the weekend are dodgey.
Are the pivots free moving?
Cable running properly through the brake?
Yes they are nice and smooth and I checked the cables.
link1896
Mr Greenfield
use a wire brush on the angle grinder to add texture to the breaking surface across the braking surface for micro roughening, and a screw driver to add big gouges to the surface for macro texture. won't be smooth, but doing this on mavic rims with XT v brakes got close to dry disk braking on 160mm rotors back in the day (rose colour goggles on mind you)
lightbrain about 4pm
Back in the bad old days... clean the braking surface with isopropol alcohol before scuffing the surface and then clean it again after. You can easily embed grime and stuffs in the texture on the rim. Same applies to using adhesives on aluminium, clean it thoroughly first, then roughen the surface.
rowdyflat
chez le médecin
Good soft brake pads like Swissstop toed in , clean rims, lube cables and get the thought out of your head that they will be nearly as good as discs.
  • Like
Reactions: PJO
Freediver
I can go full Karen
Front of the bike to the left then rim direction runs left to right - I swear I'm not typically OCD - like I said not sure why this bothers me - maybe I acquired a brain injury?
Are your feet on backwards and are they your reference point? My toes are at the front and my heel is at the back.
  • Like
Reactions: PJO
